Measure
current transducer (0 -3A) then connect to PCI 6220
I am looking for a current Transducer that works look like a "Lecroy Current probe (CP015)" or something like that wherein you just measure the currrent by hooking the wire to measure.  This way I am not interferring the circuit. Please see attached picture file. The expected current is 3Amp Max. and the resolution at least 5mA.  Transducer should have Analog output.  Then, I am going to connect the Analog output to NI PCI 6220 Analog Input.
DOes anybody know a vendor that sells the current tranducer I want?
(5,930 Views)
I would recommend searching a website such as www.digikey.com or www.mouser.com to search for a transducer to fit your application.
Justin
Justin
Product Support Engineer - Conditioned Measurements
(5,905 Views)
