Measure
Which pins do I use to receive data from PDS ELITE RS485 with the PXI 8431/2?
Hello!
I am using the PXI 8431/2 to read out data from the PDS ELITE flowmeter (Modbus RTU). For receiving data, the RS485 protocol asks for pin 4 and 5, but this configuration does not seem to work. When I connect the RS-485 to USB converter from Microflex I do receive the data properly, so somehow between the pin lay out and the PXI there is this problem.
Can somebody help me out?
Cheers,
Steven
(8,124 Views)
Could you check the below link?
http://force.natinst.com:8000/pls/ebs/niae_screenpop.main?p_incident_number=877874
Hope this helps.
Kind regards,
Hossein
(8,120 Views)
Hello Hossein,
your link is not working. Even https://force.natinst.com/ is not found with my browser...
Rgds,
Steven
(8,117 Views)
Accepted by StevenSablerolle
Hello Steven,
I think what Hossein was trying to send you is this:
How do I Connect and Configure a 2-Wire Device With RS-485
Can you also tell me a bit more what you are using to read the data? What environment. Do you have 2 wire or 4 wire Modbus RTU?
Rik Prins, CLA, CLED
Software Development Engineer
(8,107 Views)
Hello Rik,
thank you very much! As I followed the link, we have shortcutted pin 4 with 8 and 5 with 9. Setting the it to half-duplex, the transmitter and receiver data can now go through the 2 wire cable.
Best regars,
Steven
(8,090 Views)
