Measure
Why there are self-excited oscillation on Voltage input on PCI-6229 Card?
hello,
I am using PCI-6229 card to aquisite voltage from a photo diode.
I use differential mode to connect plus node on ai21 and nagetive on ai29 of PCI-6229.
this corresponding with terminal 60 & 26 on SCB-68 connector.
But after several seconds the voltage will climb on to the maximum 10V even I leave the terminal of ai21 & ai29 open.
Is it normal of PCI-6229 ?
How to solve this problem?
Thanks a lot!
(6,078 Views)
