Measure
Will not install
I just got my copy of Measure 2.0. My computer is running Windows XP Pro. I put the disk in the drive, the install window pops up. I click on Install, and nothing else happens. Bad disk, bad program or what?
(6,866 Views)
I found a way of working around this problem. Start the computer in safe mode and the program installs like it should. Then restart in the normal fashion and the program will work correctly. I must have a driver somewhere that the install portion does not like.
(6,835 Views)
