Home
Community
Discussion Forums
Additional NI Product Boards
Measure
Topic
Measure
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Wiring up conector block CB-68LPR
mikegordon
Member
09-25-2006
03:49 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
hey:
I didn't receive any paperwork on wiring up the two connector blocks that I
installed into the CA1000 chassis. I have 16 BNC connectors on the front
panel
0
Kudos
Message
1
of 2
(8,569 Views)
Reply
Re: Wiring up conector block CB-68LPR
50ohmTerminator
NI Employee (retired)
09-26-2006
06:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hey Mike,
The CB-68 LPR is just a 68 pin connector block. The screw terminal numbers should correspond the pin out for the card that you are using. Have you got a chance to look at the datasheet for the
CA-1000
Let me know if you have any more questions.
Have a good one.
Malay
NI
0
Kudos
Message
2
of 2
(8,560 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
