Measure
Wiring up conector block CB-68LPR
hey:
I didn't receive any paperwork on wiring up the two connector blocks that I
installed into the CA1000 chassis. I have 16 BNC connectors on the front
panel
(8,593 Views)
Hey Mike,
The CB-68 LPR is just a 68 pin connector block. The screw terminal numbers should correspond the pin out for the card that you are using. Have you got a chance to look at the datasheet for the CA-1000?
Let me know if you have any more questions.
Have a good one.
Malay
NI
(8,584 Views)
