Measure
how to communicate with an instrument thru LAN
I have MAX and I can' t view my instrument I connected through LAN. How do i communicate with my instrument thru LAN (eg sending commands)?
thanks
(7,125 Views)
Did you right click on Devices and Interfaces and select Create New>VISA TCP/IP Resource. What you do after that will depend on whether it's on your local subnet and whether it's a VXI-11 instrument.
p.s. You posted on the Measurement board and that is for the NI program called Measure which is an add-on for Excel. You should post further questions to the Instrument Control board.
(7,117 Views)
This KnowledgeBase and Tutorial have some more information on creating a TCP/IP resource in MAX and communicating with it.
Hope this helps!
(7,105 Views)
