Measure
how to connect a male 6 pin mini din connector to an RJ-50 connection
Wondering if anyone has any idea how to connect a sensor with a male 6 pin mini DN connecto to the NI 9237 which requires an RJ-50 connection. Please give me some ideas. Thanks!
(8,201 Views)
Take a look at page 6 http://www.ni.com/pdf/manuals/374186e.pdf .
It should give you a place to start. You'll need to know the details of what each wire is on your DN conntector, but that should get you started.
(8,191 Views)
Any update on this - I'm trying to do the same (male 6 pin mini din to RJ-50 for NI-9237). The link to the manual above is no longer active.
(4,730 Views)
Hi c.nelson,
Try looking at http://www.ni.com/pdf/manuals/374186f.pdf .
On pages 10,11 it gives the pinout for the RJ-50 connection, and should get you started connecting.
(4,723 Views)
