Measure
the current i/o channels
i have ni6229
what is maximum current for digital output channel
whatis the solution for :
if i need use mechanical relay (input volt 5 vDc) but it has input current grater then 20 mA
(7,103 Views)
Hello engmoh,
The maximum current for the digital output channels on the 6229 can be found in the following KnowledgeBase article:
http://digital.ni.com/public.nsf/websearch/383AE78B7744B3E686256F26005B3F42?OpenDocument
The information in that article can be found in the M Series Help which can be found here:
http://digital.ni.com/manuals.nsf/websearch/9477D6DF1FE5A72986256FAB00633DE4?opendocument
I hope this helps!
E.Lee
Eric
DE For Life!
(7,094 Views)
