Measure
where can I get version 1.0 of measure?
I'm trying to run an old program that requires lotus 123 v2.x or less and national measure v1.0. I need a dos version that will install from floppies.
(7,048 Views)
Hello, I am also looking for Measure 1.0. Have you been successful? Thanks for feedback. MG
(6,706 Views)
You should know that NI does not provide active support for measure because it is more than 10 years old.  That means you will not be able to get copies of that software from NI.  Having said that I found a document that contains all the remaining support information for that product: Measure Document.
Eric A.
Distributed I/O Product Support Engineer
(6,698 Views)
