Measure
Help with ...2 wire multi-tone technique for inductance measurements
What's the diference between having a DMM to measure resistance and a LCR? I've seen many ATE's with both equipments, a DMM and LCR, the first one it is used to measure resistance (2 or 4 wire method) and the other one it is used to measure inductance or capacitance (always in 4 wire method). Why don't use the same device to do both measurements? Can I use a NI PXI7042 in order to get resistance and inductance from a DUT? Does multi-tone technique eliminates in someway the use of 4-wire method?
 has something to do with the DMM voltage-frecuency delivery capacity?
Any further explanations or comments will be most welcome!
(6,954 Views)
You're more likely to get a response if you post to the Digital Multimeter board for questions about NI DMMs. This board is for the add-in program to Excel called 'Measure' and not for general measurement questions.
Message Edited by Dennis Knutson on 10-03-2007 02:37 PM
(6,949 Views)
Hi LVocho,
You can use the PXI-4072 to measure resistance and inductance of an UUT.
If I am correct, the traditional way to measure inductance and capacitance technique uses a sine wave and a precision synchronous detector.
The PXI-4072 DMM uses a multi-tone signal, basically it generates a very precise square wave (in frequency domain has many frequency contents) and it’s harmonically limited.  You can find more details in the NI Digital Multimeters Help File:
https://www.ni.com/docs/en-US/bundle/ni-dmm/page/ni-dmm.html
And in the Getting Started Guide NI Digital Multimeters:
https://www.ni.com/docs/en-US/bundle/ni-digital-multimeters-getting-started/resource/ni-digital-mult...
Also you will find very useful information in this page:
https://www.ni.com/en/shop/electronic-test-instrumentation/digital-multimeters/dmm-measurement-funda...
Specifically look at:
https://www.ni.com/en/support/documentation/supplemental/06/capacitance-and-inductance-measurements-...
http://zone.ni.com/devzone/cda/tut/p/id/3713
Please let me know if you need more information.
Tania Lozoya | National Instruments | Mexico
(6,942 Views)
