ASAM XIL INtegration with NI Veristand
We are integarting ASAM 2.1 version with Veristand using .net and the setup is Linux RT but getting "Setting value out of range or unknown setting option"
(120 Views)
When integrating ASAM 2.1 with VeriStand on a Linux RT target through the .NET API, the error “Setting value out of range or unknown setting option” usually indicates a mismatch between what the ASAM client is trying to set and what VeriStand actually supports. This can happen if the parameter name does not exist in the deployed system definition, if the value being written is outside the defined min/max range, or if the feature is not supported on the Linux RT environment even though it works on Windows. It can also occur due to type mismatches, such as sending an integer to a channel expecting a floating-point value. To resolve this, first confirm that the parameter or channel exists and matches your XIL configuration, then check the allowable range and data type in System Explorer, and finally test with a simple user-defined channel to rule out RT compatibility issues.
(41 Views)
Thanks for the reply. for 2.1 version of ASAM tool is working Good. But now I have 2 queries as below
1. Is there a way to avoid redeploying of system definition file if its already deployed when we use port.configure() method in c#
2. we have 2.0.1 version of ASAM and dont see any reference of Port configuration file for this. Can u please help me with this if you have any idea on this topic
(35 Views)
