Adding multiple global virtual channels
I had a very simple function written in CVI that adds multiple global virtual channel
DAQmxErrChk (DAQmxAddGlobalChansToTask(g_TaskHandle, linesName)); //linesName consists 2 global virtual channels seperated by ",". E.g. "Power, Com" where Power = port1/line0 & Com = port1/line2
 There is AddGlobalFunction in MEasurement Studio too but it allows adding single channel only:
Task localTask = new Task();
localTask.AddGlobalChannel(linesName); //Get Expetion here = -200486, Specified Channel not in the task. When I give a single channel name..it works
DigitalSingleChannelWriter doWriter = new DigitalSingleChannelWriter(localTask.Stream);
doWriter.WriteSingleSampleMultiLine(true, states); //atates is the array of type bool which consists of value for each channel
 Is it not possible any more to add multiple Global Channels to a task??
We have recently acquired Measurement Studio license and are trying to port/compile/write our old libraries (written in CVI) in it.
- Is there any online help that compares CVI C functions with respective .NET functions of DAQmx?
Thanks in advance!
Ciao
Ricky
(7,750 Views)
Have been trying this for last 2 days, have also searched number of NI forum messages but have not got solution.
Anyone with slightest of hint?
(7,702 Views)
Meanwhile I have gathered some more Information:
- Adding multiple Global channels in LabWindows/CVI is possible using DAQmxAddGlobalChansToTask function where channels are , (comma) seperated
- Also adding multiple Global channels in LabView  where channels are , (comma) seperated.
May be I am wrong but has NI forgotten to implement the same in MeasurementStudio ? Or am I missing something?
(7,691 Views)
Accepted by dotNet_to_LabW
it seems like you are correct. The definition of the method specifies that it only adds one channel:
public NationalInstruments.DAQmx.Channel AddGlobalChannel(string channelName)
    Member of NationalInstruments.DAQmx.Task
Summary:
Adds a preconfigured, global channel to the task.
Parameters:
channelName: The name of the global channel to add to the task.
Returns:
The global Channel.
Exceptions:
NationalInstruments.DAQmx.DaqException: The NI-DAQmx driver returned an error.
This could be explained by the fact the function returnes the appropriate instance of the channel object related to the global virtual channel you created.
I tried to check the code reading 2 Global Virtual Channel using the DAQ Assistant in Measurment Studio but I was not able to get much of it (the generated code makes two consecutive calls of the "CreateVoltageChannel" method.
What happen if you call AddGlobalChannel twice?
localTask.AddGlobalChannel("Power");
localTask.AddGlobalChannel("Com");
I did not have time to try this so far, but from my understanding of the help file, I assume it could work.
Best regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(7,652 Views)
It worked!
Sorry, I did not even think about calling the function with different channels multiple times.
Thanks for your help!!
(7,629 Views)
