Am writing a project to communicate with wt3000 power analyser using .NET. In file save mode "PC CARD" is default one. How can I change the path to my local computer hard disk drive. Am using GPIB interface for communication
Am writing a project to communicate with wt3000 power analyser using .NET.  In file save mode "PC CARD" is default one. How can I change the path to my local computer hard disk drive. Am using GPIB interface for communication. If any one knows kindly reply immeditely
(3,757 Views)
Hey guruprasad
I want to help you as best as I could, but I have a couple of questions about your applications
1. Are you saving on your PC or on your Device?
2. You said that you were using a GPIB interface, could you be more specific on which card you're using?
3. Are you using the instrument driver from NI ?
Can Wong
(3,741 Views)
Thank u .
    Here is answer for ur Question.
       1. I want to save in my pc. (In which file format it is save?)
       2. PCI-GPIB Interface card.
       3. Yes am using Instrument Driver from NI   (NI-488.2 for Windows, Version 2.5.2)
    Also am using .NET 2003 and C# language for this project.
(3,737 Views)
It looks like you can change the settings to where your project is saved by going to
Tools->Options->Project and Solutions->General
and changing the path for you project. This is different depending on what software you're using to program with, but they all should have a similar method of changing the path.
Hope this helps
Can Wong
(3,725 Views)
