Use MouseMove event to display x and y axis position in c#
I am trying to display the x and y axis position whenever a user moves the mouse over the graph.  it will update a text box.  I tried to use the mousemove event but i only get the location of the mouse and not the x and y value.  What do i use to get those values.  Thanks
(13,949 Views)
Hi Layzie292,
You can use the InverseMapDataPoint method as shown below:
private void mouseMove(object sender, MouseEventArgs e)
   double xData, yData;
   Point p = new Point(e.X, e.Y);
   waveformGraph1.Plots[0].InverseMapDataPoint(waveformGraph1.PlotAreaBounds, p, out xData, out yData);
   textBox1.Text = xData.ToString();
   textBox2.Text = yData.ToString();
If you don't have that method (I can't remember which version first introduced it), refer to this post
Best Regards,
Jonathan N.
(13,943 Views)
That worked great
(13,942 Views)
