Any tips on how to anchor and dock multiple graph windows so they expand equally to fill screen in any resolution?
We are using NI Waveform and Scatter Graph objects. We stack three graphs on one screen, and must display on screens from 640x480 to high res.
Have tried anchoring graphs to "top & left" and dock all to "top". This causes graphs to expand out to right of screen at any res, but they do not expand toward bottom of screen. When try to change anchor points or docking, e.g. set the graph at bottom to "fill" docking, it alone expands in the Y direction.
I have also checked "Make Same Size" in the layout bar when referencing the three graphs.
Can anyone suggest a further refinement or another approach to do this, so all three expand equally in both the hor
izontal and vertical dimensions?
We have a similar layout issue on another screen where two graphs are used along with several text boxes and numeric controls, with the graphs at top and bottom of screen.
(4,169 Views)
Hey Pete,
Have you tried going into File > VI Properties, selecting Window Appearance from the drop-down menu, and then placing a check mark in 'Scale all objects on front panel as window resizes'?
(4,169 Views)
Jared,
Are you referring to a LabView (VI) option?
(4,169 Views)
Yes, yes I am. Looks like I neglected to read the group you posted this in... Visual Studio.net? Is that where you are trying to do this?
(4,169 Views)
Yes, using the Measurement Studio controls.
(4,169 Views)
