We are using NI Waveform and Scatter Graph objects. We stack three graphs on one screen, and must display on screens from 640x480 to high res.
Have tried anchoring graphs to "top & left" and dock all to "top". This causes graphs to expand out to right of screen at any res, but they do not expand toward bottom of screen. When try to change anchor points or docking, e.g. set the graph at bottom to "fill" docking, it alone expands in the Y direction.
I have also checked "Make Same Size" in the layout bar when referencing the three graphs.
Can anyone suggest a further refinement or another approach to do this, so all three expand equally in both the hor
izontal and vertical dimensions?
We have a similar layout issue on another screen where two graphs are used along with several text boxes and numeric controls, with the graphs at top and bottom of screen.
