AnyCharacterReceived method help.
I am reading data from a serial port. When each character arrives the serial session fires the AnyCharacterReceived event. How do I write this handler in C#, i.e. not the body of the code but the method prototype, etc. Can someone give an example.
(4,614 Views)
Hello Barry,
the AnyCharacterReceived event is of type SerialSessionEventHandler, which has a signature of
void SerialSessionEventHandler (object sender, SerialSessionEventArgs e);
Your event handler needs to have this same signature:
private void MyEventHandler(object sender, SerialSessionEventArgs e)
SerialSession session = (SerialSession)sender;
//Code to handle event goes here.
You then connect your event handler to the event with the += operator:
mySerialSession.AnyCharacterReceived += new SerialSessionEventHandler(this.MyEventHandler);
(4,609 Views)
Thanks Glen,
Here is what I have:
A serial dialog box contains a button that opens the serial port. The open port click event looks like the following:
private void buttonOpenPort_Click(object sender, System.EventArgs e)
try
if(PortOpen == false)
this.buttonOpenPort.Text = "Close Port";
this.ledPortOpen.Value = true;
PortOpen = true;
sessionTreeView.Nodes.Clear();
string Port = Configuration.ComPort;
string CurrentSession = "ASRL" + Port + "::INSTR";
//OK, let's open it.
session = ResourceManager.GetLocalManager().Open(CurrentSession);
CurrentSerialSession = session as SerialSession;
if (CurrentSerialSession != null)
this.CurrentSerialSession.AnyCharacterReceived += new SerialSessionEventHandler(this.CharacterReceived);
CurrentSerialSession.BaudRate = Convert.ToInt32(Configuration.BaudRate);
CurrentSerialSession.DataBits = Convert.ToByte(Configuration.DataBits);
(4,596 Views)
Thanks Glen,
try
//some other stuff
catch(problems)
The CurrentSerialSession is defined in
public class frmSerialDialog : System.Windows.Forms.Form
private Session session;
private SerialSession CurrentSerialSession;
private Session TempSession;
private SerialSession DisplayCurrentSerialSession;
private bool PortOpen;
// at the top of the class.
//on down I have:
private void CharacterReceived(Object sender, SerialSessionEventArgs e)
SerialSession ReceiveSerialSession = (SerialSession)sender;
int NumberOfBytes = ReceiveSerialSession.AvailableNumber;
textBoxReceive.Text = ReceiveSerialSession.ReadString(NumberOfBytes);
the CharacterReceived event is never firing even though I know that characters are coming in on the serial port. The question is,
where should the statement
go?
Barry
(4,596 Views)
Sorry Barry, I left out a critical piece:
After you add the event handler, put this line:
CurrentSerialSession.EnableEvent(SerialSessionEventType.AnyCharacterReceived, EventMechanism.Handler);
this tells the serial session to actually monitor for that particular event.
(4,571 Views)
