Read multiple counter in c# aplication
How can I read multiple counter in my buffered aplication write in c#. I use 6601 and 6602 devices. When I try readeng all counter in my alication, I can read just two counter ( one from 6601 device and one from 6602 device). Thanks in advance for the help,
Otto
(4,868 Views)
Hi Otto-
You should be able to read from multiple counters easily. You will need to group each counter into a seperate task if you want to run them concurrently. I have attached a C# example that shows how to count buffered digital pulses on one counter with an external clock. This should give you a starting point to modify for multiple counters.
I hope this helps!
Thanks-
Tom W
(4,847 Views)
Hi Tome.
When I triying use two counter concurrently I give this message:
No DMA channels are available.
Either shut down other tasks that might be using these channels or consider changing your data transfer mechanism to Interrupts.
Device: Dev2
Task Name: ciTask
Status cod: -200251
See my cod in attachment.
Otto.
(4,835 Views)
Hi Otto-
I have been able to run your app successfully on my system. Everything seems well-designed and structured, so I would suggest that you try it on a different system. Make sure that you're not running any other hardware operations at the same time, and remove any other PCI cards from the system if possible.
I hope this helps!
Thanks-
Tom W
(4,809 Views)
Hi Tom
How can I change the default source pin in main counter aplication?
Otto
(4,792 Views)
Hi Otto-
The counter pins can be changed by a variety of options as described in the DAQmx C Reference Help (Start>>Programs>>National Instruments>>NI-DAQmx).  For a count edges input task the relevant property is "DAQmxSetCICountEdgesTerm(TaskHandle taskHandle, const char channel[], const char *data);"
I hope this helps!
Tom W
(4,778 Views)
