Arrow From Point
I want to draw an arrow from a specific point in the graph (I have the position of the point relatively to the axes), in fixed length, with specific angle.
Currently, I found option to draw only arrow from label to point (in PointAnnotation):
PointAnnotation point = new PointAnnotation();
point.HorizontalPosition = arrow.Position.X;
point.VerticalPosition = arrow.Position.Y;
point.TargetSize = new Size(0, 0);
point.ArrowBrush = new SolidColorBrush(arrow.Color);
point.ArrowVisibility = System.Windows.Visibility.Visible;
point.ArrowHeadShape = PointShape.OutwardTriangle;
point.LabelAlignment = new AnnotationLabelAlignment(BoundsAlignment.None, 100, 100);
I got this as a result:current.PNG
Is there any way to draw an arrow between two points in the chart (relatively to the axes, not by pixels)?
(3,395 Views)
Accepted by YEHUDIT
Using code to translate between data and screen coordinates, it is possible to calculate the required position to draw a line between two data points with a PointAnnotation. I have included the relevant code below (see the attached example for more details):
    Point screenStart = graph.DataToScreen( plot, new[] { dataStart.X, dataStart.Y } );
    Point screenEnd = graph.DataToScreen( plot, new[] { dataEnd.X, dataEnd.Y } );
    point.HorizontalPosition = dataStart.X;
    point.VerticalPosition = dataStart.Y;
        screenEnd.X - screenStart.X,
        screenEnd.Y - screenStart.Y );
If this proves insufficient, you could implement a new IRenderable type (which is what the point annotation derives from), to perform custom rendering logic.
~ Paul H
(3,368 Views)
Thank you very much!
It's exactly what I searched for!
(3,356 Views)
