Best way to display limit "range"
I have to test every single point on my plot against Min/Max values specific to location.  I made everything work but I'd like to better indicate valid channel on the Graph.
This is what I have...  As you can see, the bold blue line is the actual data and thin blue lines represent the valid channel my data has to fall in.  If it's outside the channel, I mark those points in red.
This ^ is sufficient but I'd like to make something like picture below, if possible and isn't "expensive" (I mocked this up in Painshop):
Thanks!
(5,019 Views)
Accepted by kirko7
("Painshop" — that must have hurt! 🙂
I would suggest using an AreaPlotRenderer for the minimum and maximum plots, configured with a FillBaseline of NegativeInfinity and PositiveInfinity, respectively:
    <ni:Graph>
        <ni:Graph.Plots>
            <ni:Plot Label="Minimum Plot">
                <ni:AreaPlotRenderer FillBaseline="NegativeInfinity" />
            </ni:Plot>
            <ni:Plot Label="Maximum Plot">
                <ni:AreaPlotRenderer FillBaseline="PositiveInfinity" />
            </ni:Plot>
        </ni:Graph.Plots>
    </ni:Graph>
~ Paul H
(5,013 Views)
Bucket Fill is your friend LOL.
I love how flexible your tools are!  This is working very nicely but I just wanted to ask if it's possible to set Opacity in this line or does it have to be done separately down the road.  I have a hardcoded collection of plots that I use throughout my applications.
Thanks!
private static readonly AreaPlotRenderer AreaPlotRendererNegative1 = new AreaPlotRenderer() { Fill = Brush1, FillBaseline = FillBaseline.NegativeInfinity };
(5,000 Views)
Accepted by kirko7
On the "Brush1" value you are using, you could set Opacity, or use a Color with a lower alpha value (for a solid color brush).
~ Paul H
(4,995 Views)
It's a beaut!
(4,987 Views)
Very nice!
~ Paul H
(4,983 Views)
