Best way to implement Notch Filter in VB.NET 2008?
I am trying to design a notch filter for the 60hZ frequency. However all I am coming up with is information in LabView. Does anybody know how this filter would be implemented in VB.NET 2008?
(3,758 Views)
Hi Tweed,
You can take a look at the filtering example that comes with Measurement Studio and is located in the following directory:
<National Instruments>\MStudioVS2008\DotNET\Examples\Analysis\Filtering\vb
You can use the band-stop filter option to achieve a notch filter and you can either modify the example or copy the necessary code in order to do what you need.
Ryan T
(3,716 Views)
