Best way to keep X axis range changes in combination with FitExactly
Maybe it's a weird request but I hope there's a good way to handle it.
I have a Graph control with X Axis set to Adjuster="FitExactly" and it works beautifully on window initialization.
Thing is, we want to be able to manually adjust X value (by editing the last X value on the Graph X Axis) and keep this value if data is reloaded.  At the monent it's reset due to FitExactly setting.
What would be the best solution for this?
Thank you.
(3,798 Views)
Accepted by topic author kirko7
The simplest approach might be to use a custom RangeAdjuster implementation that uses the current range until FitExactly returns a different value:
    public sealed class CachedRangeAdjuster : RangeAdjuster {
        private IRange previousRange;
        protected override Range<TData> GetAdjustedRangeCore<TData>( RangeAdjusterArgs<TData> args ) {
            Range<TData> exactRange = FitExactly.GetAdjustedRange<TData>( args );
            Range<TData> result;
            if( object.Equals( previousRange, exactRange ) ) {
                result = args.Range;
            else {
                previousRange = exactRange;
                result = exactRange;
            return result;
~ Paul H
(3,794 Views)
Thanks!
Will try once I get back from vacation.
(3,778 Views)
