Blank LED Indicator On Windows 7
Hi bnils,
It is intriguing that you are receiving the prompt.  This leads me to believe that the administrator elevation is happening as expected.  I'll have to do some more research and get back to you.
Hassan Atassi
Senior Group Manager, Digital Support
Message 21 of 23
(1,079 Views)
I was able to reproduce the behavior you were experiencing with your Windows 7 Deployment. I am going to be filing a bug report so that our R&D group can investigate this further. In the meantime, there are two workarounds.
1. Running setup.exe as administrator will give the installer the permissions necessary to add the registry keys that will link the MESA.dll.
2. You can edit the .vdproj file that is built with the installer. Search for the line "RequiresElevation" = "11:FALSE" and change the value to "11:TRUE". This will make the installer ask for administrative priviledges to run. You can read more about this under the Application Elevation topic here.
Thank you for your patience and feedback. Please let me know if you have any questions.
Message 22 of 23
(1,072 Views)
Great, both workarounds seem to work!
Best regards, Björn Nilsson.
Message 23 of 23
(1,035 Views)
