C# DAQMX Dynamicly change task AI channels
I would like to ask if is somehow possible to dynamicly change/add or remove) in code list of analog input channels in same task without dispose task?
Regards!
(5,921 Views)
It is possible to change them in LabVIEW
Dynamically Change the Lines in a DAQmx Analog Input Task Using an Event Structure   https://decibel.ni.com/content/docs/DOC-7103
Thereferore it should be possible in C too.
(5,893 Views)
thanks for reply.
If I understand correctly you need to clear-dispose task and then create new task. This takes quite some time.
Isn't it possible to create task than START, acquire signal, STOP, UNRESERVE and then reconfigure channels in task(remove old, add new)?
Regards!
(5,880 Views)
Unfortunately not.
In order to change physical channels DAQmxCreateTask(), DAQmxStopTask() and DAQmxClearTask() has to be used.
Andrej Korošec,
AE NI EE
(5,860 Views)
