Info 1923. Service 'NI PSP Service Locator' (lkClassAds) could not be installed.
Hello Everyone.
I have problem to deploy Measurement studio application with msi installer.
My project is stated few year ago, the installer work great up to yesterday, this is my msi log
MSI (s) (B4:A8) [11:54:48:312]: Executing op: ProgressTotal(Total=4,Type=1,ByteEquivalent=1300000)
MSI (s) (B4:A8) [11:54:48:312]: Executing op: ServiceInstall(Name=lkClassAds,DisplayName=NI PSP Service Locator,ImagePath=C:\WINDOWS\system32\lkads.exe,ServiceType=16,StartType=2,ErrorControl=0,,,,StartName=NT Authority\NetworkService,Password=**********,Description=Locates servers at the request of network variable clients and other proprietary NI network protocols. If this service is stopped or disabled, network variables and network streams will stop working.)
MSI (s) (B4:A8) [11:54:48:312]: Note: 1: 2262 2: Error 3: -2147287038
Info 1923. Service 'NI PSP Service Locator' (lkClassAds) could not be installed. Verify that you have sufficient privileges to install system services.
Action ended 11:54:48: InstallExecute. Return value 3.
MSI (s) (B4:A8) [11:54:48:328]: User policy value 'DisableRollback' is 0
MSI (s) (B4:A8) [11:54:48:328]: Machine policy value 'DisableRollback' is 0
Do you have any idea about this issue??
(8,020 Views)
Which versions of Measurement Studio and Visual Studio are you using?  Also, which OS (both for the development and deployment machines)?
Sometimes this problem can occur if the NI PSP Service Locator is already running on the machine that you are trying to run the installer on.  Could you check in your Windows Services and see if this is the case?  If so, go ahead and stop the service before running the installer again.
(7,990 Views)
