Where can I find NationalInstruments.NiLmClientDLL.dll and NationalInstruments.Common.Native.dll for x64
Hi!
I have installed the NiDAQmx package, but I can't seem to find all required dlls for deployment. On the page http://zone.ni.com/reference/en-XX/help/370473H-01/mstudiowebhelp/html/netdeploymentfiles/ there is information about where to find the 64-bit versions: "The 64-bit version of the following assemblies is located in the Program Files\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies (64-bit)\Current directory".
In this folder I can not find the NiLmClientDLL and NationalInstruments.Common.Native.
If I understand it correctly, the DAQmx is dependent on Common, which is dependent on Common.Native and NiLmClientDLL.
What have I missed?
Message 1 of 10
(9,550 Views)
@thomasd14333 wrote:
Hi!
What have I missed?
Did you install NI-DAQmx with .NET support?
Message 2 of 10
(9,545 Views)
In the installer I selected Custom -> Application Development Support -> .NET Framework 4.0 Language Support
Message 3 of 10
(9,541 Views)
I am on a Windows 8.1 machine, and NationalInstruments.Common.Native.dll is in C:\Program Files (x86)\ subdirectory.
Message 4 of 10
(9,537 Views)
Sorry, I mixed up the names (of Common and Common.Native). I also find the Common.Native.dll in that folder.
However, I can not find the NiLmClientDLL.dll (and Common) in the folder C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies (64-bit)\Current. Do you have those assemblies in that folder? The folder on my computer only includes NationalInstruments.Common.Native.dll and NationalInstruments.DAQmx.dll.
Message 5 of 10
(9,526 Views)
Do you have a license for Measurement Studio?
Message 6 of 10
(9,515 Views)
No, I don't (myself) have a license for MS. I have just installed the NIDAQmx package. I am converting a deployment package from x86 to x64, and are trying to find the required dlls.
Message 7 of 10
(9,513 Views)
I have NI-DAQmx 9.9.0 installed, and I do not have that DLL.
I do have Measurement Studio installed either.
That NI webpage you linked specifically says that is is for deploying a specific feature of Measurement Studio.
I don't know how you expect to do that, if you don't have Measurement Studio.
Message 8 of 10
(9,504 Views)
Sorry, that was maybe not a good link... didn't notice that it only targeted deploy of MS specific functionality.
However, if I investigate the DAQmx dll, I see that there is a dependency to the Common dll, and from that dll there are dependencies to the Native and NiLmClientDLL dlls. I was (maybe not correct) assuming that I needed x64 versions of all these, not only DAQmx and the Native ones.
I'll try to install Measurement Studio.
Message 9 of 10
(9,495 Views)
Forgot to mention in previous post: I assume that the NationalInstruments.Common and NationalInstruments.NiLmClientDLL dlls are compiled for AnyCpu, and that I can use those.
Message 10 of 10
(9,490 Views)
