CWIMAQdx.OpenCamera always returns camera not found even with proper interface name
i have a C# code snipped for low level grab functionality as shows below :
String str = String.Empty;
status = CWIMAQdx.OpenCamera("img0", CWIMAQdx.CameraControlMode.Controller,out session);
if (status != CWIMAQdx.Error.Success)
CWIMAQdx.GetErrorString(status, out str);
MessageBox.Show(str);
But the error message everytime i get is Camera not found even with the correct camera interface name as img0 which i took from MAX.
Kindly help.
Thanks in advance.
Regards
Ritesh
(3,467 Views)
I am using NI Smart camera 1742. I have created a simple processing of grabbing a frame and increasing its brightness in vision assistant and created a vi for the same using vision assistant. but on running the vi it says "camera no found"... how can i solve this?i need urgent help
(3,258 Views)
