04-19-2014 08:26 PM
The callback in the added code doesn't work. The callback code has a comment of <------- CALLBACK NOT WORKING behind it. It just go through the ContSampleThrmcpl code once and then it just terminates. There are no compiler warnings as well. Google isn't of much help either. Anyone knows whats wrong?
With kind regards,
Yami_Bas
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using System.Data;
using NationalInstruments.DAQmx;
namespace TorrefractieCS
public class ContSampleThermocouple
private AnalogMultiChannelReader analogInReader;
private AsyncCallback analogCallback;
private NationalInstruments.AnalogWaveform<double>[] data;
private Task myTask;
private Task runningTask;
private DataColumn[] dataColumn = null;
private DataTable dataTable = null;
private int sampsPerChanGlobal;
private int counter = 0;
public void ContSampleThrmcpl(string channels, int sampleRate, int sampsPerChan, double minVal, double maxVal)
dataTable = new DataTable();
sampsPerChanGlobal = sampsPerChan;
try
Console.WriteLine("Start");
// Create task and channel
myTask = new Task();
AIChannel myChannel;
// Set properties
AIThermocoupleType thermocoupleType = AIThermocoupleType.K;
AIAutoZeroMode autoZeroMode = AIAutoZeroMode.EverySample;
// Configure channel
myChannel = myTask.AIChannels.CreateThermocoupleChannel(channels, "", minVal, maxVal, thermocoupleType, AITemperatureUnits.DegreesC);
myChannel.AutoZeroMode = autoZeroMode;
myTask.Timing.ConfigureSampleClock("", (double)sampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, sampsPerChan);
// Create analog in reader
myTask.Control(TaskAction.Verify);
runningTask = myTask;
analogInReader = new AnalogMultiChannelReader(myTask.Stream);
analogCallback = new AsyncCallback(AnalogInCallback);
// Prepare table for data
InitializeDataTable(myTask.AIChannels, ref dataTable);
// Use SynchronizeCallbacks to specify that the object
// marshals callbacks across threads appropriately.
analogInReader.SynchronizeCallbacks = true;
analogInReader.BeginReadWaveform(10, analogCallback, myTask); // <-------- CALLBACK NOT WORKING
Console.WriteLine("Amount of callbacks: " + counter);
counter++;
catch (DaqException exception)
MessageBox.Show(exception.Message);
myTask.Dispose();
runningTask = null;
public void AnalogInCallback(IAsyncResult ar) // <-------- CALLBACK NOT WORKING
Console.WriteLine("Callback");
try
if (runningTask != null && runningTask == ar.AsyncState)
data = analogInReader.EndReadWaveform(ar);
dataToDataTable(data, ref dataTable);
analogInReader.BeginMemoryOptimizedReadWaveform(10, analogCallback, myTask, data);
myTask.Dispose();
runningTask = null;
public void InitializeDataTable(AIChannelCollection channelCollection, ref DataTable data)
if (channelCollection == null)
return;
int numOfChannels = channelCollection.Count;
data.Rows.Clear();
data.Columns.Clear();
dataColumn = new DataColumn[numOfChannels];
int numOfRows = sampsPerChanGlobal;
for (int currentChannelIndex = 0; currentChannelIndex < numOfChannels; currentChannelIndex++)
dataColumn[currentChannelIndex] = new DataColumn();
dataColumn[currentChannelIndex].DataType = typeof(double);
dataColumn[currentChannelIndex].ColumnName = channelCollection[currentChannelIndex].PhysicalName;
data.Columns.AddRange(dataColumn);
for (int currentDataIndex = 0; currentDataIndex < numOfRows; currentDataIndex++)
object[] rowArr = new object[numOfChannels];
data.Rows.Add(rowArr);
Console.WriteLine("Initialize DataTable");
public void dataToDataTable(NationalInstruments.AnalogWaveform<double>[] sourceArray, ref DataTable dataTable)
Console.WriteLine("Putting data in DataTable.");
// Iterate over channels
int currentLineIndex = 0;
foreach (NationalInstruments.AnalogWaveform<double> waveform in sourceArray)
for (int sample = 0; sample < waveform.Samples.Count; ++sample)
if (sample == 10)
break;
dataTable.Rows[sample][currentLineIndex] = waveform.Samples[sample].Value;
currentLineIndex++;
04-30-2014
06:50 AM
- last edited on
07-19-2026
01:03 PM
by
Content Cleaner
Hello Yami_Bas,
Does the callback work if you set/change the following?
"analogInReader.SynchronizeCallbacks = false;"
Does this default example work?
http://zone.ni.com/reference/en-XX/help/370473H-01/mstudiowebhelp/html/daqsafelydisposetask/
I would like to troubleshoot it at my side, but I'm missing information concerning your forms to do this.
Would it be in any way possible to share the forms that you are using at your side? (eg. by sharing a zip of your sample project)
