My turn I guess. Unlicensed exception
I use VS2010 / C# with no problem.
I want to use C++/CLI on a project. This is where I get the unlicensed exception.
I have searched here and nothing helped.
Help?
Message 1 of 8
(6,659 Views)
Hey Wayne,
I have a few questions for clarity.
What version of Measurement Studio are you using?
When you say C++/CLI on a project, do you mean you are coding in one of these? From my understand, .Net languages are CLI so could you clarify?
Are you trying to use the C++?
What steps have you tried?
Is this existing code that you are trying to compile?
Which library is throwing the unlicensed exception?
Best,
Kurt
Kurt P
Automated Test Software R&D
Message 2 of 8
(6,639 Views)
  • Measurement Studio 2013
  • CLI is .net, yes.
  • C++/CLI is a .net language. But yes, I'd like to use the C++ side of it
  • I've tried several things from doing searches on this forum and website (mostly dealing with the license file).
  • No, this is a new project.
  • The WinForms Scattergraph is throwing the exception
It works great in C#. But not in C++/CLI. Same programming environment (VS 2010).
Message 3 of 8
(6,635 Views)
Hey Wayne,
It looks like this is a known issue for Measurement Studio 2013 The number is 133384. The work around suggested is to refresh the .licx file, by selecting Measurement Studio»View .NET Class Library Wizard. In the Measurement Studio .NET Class Library Wizard dialog box, deselect the Measurement Studio libraries and close the dialog box. Run the Measurement Studio .NET Class Library Wizard again and select the Measurement Studio libraries.
Let us know if this works.
-KP
Kurt P
Message 4 of 8
(6,614 Views)
I saw that in another thread. There is no Measurement Studio»View .NET Class Library Wizard on my system.
Message 5 of 8
(6,607 Views)
This refers to the "Add/Remove .NET Class libraries Wizard". Within your project, try opening up that wizard and first removing the references to Measurement Studio libraries and then adding them back in through the Wizard.
Kurt P
Message 6 of 8
(6,584 Views)
I have the same problem
But the add/remove.NET Class Libraries is not in the menu
Message 7 of 8
(6,284 Views)
The reason that the option to add/remove.NET Class Libraries is not in the menu is that you need to be inside of a Measurement Studio Project in order to have that option. Open up any example or solution and then try to select the option and it will appear.
Rob S
Message 8 of 8
(6,262 Views)
