Can I read the TDMS file with Daqmx .net library?
Hello!
I have only Labview program but not Measurement Studio.
Can I read the TDMS file with Visual Basic 2013 with the DaqMX .net library?
I add the reference "National Instruments Common".
But this code is not working.
Imports NationalInstruments
Public Class Form1
    Private Function ReadTdmsWaveform() As AnalogWaveform(Of Double)
        ' Open the file for read access.
        Dim file As TdmsFile = New TdmsFile("C:\waveforms.tdms", New TdmsFileOptions(TdmsFileFormat.Version20, TdmsFileAccess.Read))
        ' Get the channel group.
        Dim channelGroups As TdmsChannelGroupCollection = file.GetChannelGroups()
        Dim channelGroup As TdmsChannelGroup = channelGroups(0)
        ' Get the channel.
        Dim channels As TdmsChannelCollection = channelGroup.GetChannels()
        Dim dataChannel As TdmsChannel = channels(0)
        ' Read the data.
        Dim waveform As AnalogWaveform(Of Double) = channelGroup.GetAnalogWaveform(Of Double)(dataChannel)
        ' Close the file.
        file.Close()
        ' Return the waveform
        Return waveform
    End Function
End Class
I just want to read the TDMS file and save the data to memory.
What should I do for this?
Please help. Thank you for reading.
(5,774 Views)
(5,763 Views)
Thank you for your replying.
I found that information already.
But there is information about using C DLL not for Visual Basic.
I want to read the data in TDMS file in Visual Basic .NET environment.
Thanks for your concern.
(5,759 Views)
If you don't want to pay for Measurement Studio, then you had better learn how to call a C DLL in VB.NET.
Apparently, that C DLL has limited capabilities.
(5,755 Views)
nyc 이(가) 작성함:
Oh I understand now.
Thank you very much!
Have a nice day~ Smiley Happy
(5,750 Views)
