.NET Libraries in DAQmx 9.9?
I just downloaded and installed DAQmx 9.9, but can't find the .NET libraries associated with this version. I have the 9.8.45.42 libraries, but am trying to update to 9.9. The installer for DAQmx 9.9 lists the .NET Framework Languages Support, but they are all marked as "This feature will not be installed", with no way to change it.
What am I missing?
(6,614 Views)
No idea.
I have the DLLs in C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\9.9.40.39
(6,605 Views)
I double checked the MeasurementStudioVS2010 folder, but no luck. (I have VS2012 installed, so that's where I initially had checked). Does the 9.9 installer allow you to select the support libraries for installation? Or were they included for you by default?
(6,578 Views)
The answer is both.
If you already have Visual Studio installed, the 9.9 Installer will detect it.
If you installed VS afterwards, you will need to do a modify of 9.9 installation through Control Panel.
(6,573 Views)
Can you tell me which versions of NI software you have installed?
I do already have VS2012 installed, but the installer for DAQmx 9.9 either isn't detecting it or I'm perhaps missing some sort of other software requirement? I also attempted to modify the installtion through the options in the Control Panel, but again, the .NET support libraries were disabled.
(6,557 Views)
I have C# Express 2010 which was installed after DAQmx 9.9
Just do a re-install of DAQmx 9.9
That may be easier for you.
(6,544 Views)
