Can't run my program after installing it on another PC
I created an installed project and tried installing my program on another PC. It won't run and throws the following error. Any ideas?
*** Exception Text ***
System.TypeInitializationException: The type initializer for "DEER_DAQ.modDeclarations" threw an exception. ---> System.IO.FileNotFoundException: File or assembly name NationalInstruments.DAQmx, or one of its dependencies, was not found.
File name: "NationalInstruments.DAQmx"
at DEER_DAQ.modDeclarations..cctor()
--- End of inner exception stack trace ---
at DEER_DAQ.modFunctions.ReadInit()
at DEER_DAQ.frmMain.frmMain_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
*** Loaded Assemblies ***
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
DEER DAQ
Assembly Version: 1.0.2329.15806
Win32 Version: 1.0.2329.15806
CodeBase: file:///C:/DEER%20DAQ/DEER%20DAQ.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
NationalInstruments.UI.WindowsForms
Assembly Version: 8.0.11.236
Win32 Version: 8.0.11.236
CodeBase: file:///c:/windows/assembly/gac/nationalinstruments.ui.windowsforms/8.0.11.236__4544464cdeaab541/nationalinstruments.ui.windowsforms.dll
CodeBase: file:///c:/windows/assembly/gac/nationalinstruments.ui/8.0.11.236__4544464cdeaab541/nationalinstruments.ui.dll
NationalInstruments.Common
Assembly Version: 8.0.11.194
Win32 Version: 8.0.11.194
CodeBase: file:///c:/windows/assembly/gac/nationalinstruments.common/8.0.11.194__4544464cdeaab541/nationalinstruments.common.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Web
Win32 Version: 1.1.4322.2037
CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
NationalInstruments.UI.Styles3D
Win32 Version:
CodeBase: file:///c:/windows/assembly/gac/nationalinstruments.ui.styles3d/8.0.11.236__4544464cdeaab541/nationalinstruments.ui.styles3d.dll
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
Message 1 of 8
(5,848 Views)
The program directory is as follows:
 Directory of C:\DEER DAQ
05/18/2006  10:21 AM    <DIR>          .
05/18/2006  10:21 AM    <DIR>          ..
05/18/2006  10:09 AM    <DIR>          bin
05/18/2006  10:02 AM    <DIR>          Data
05/18/2006  09:53 AM           360,448 DEER DAQ.exe
05/18/2006  10:04 AM               901 DEER DAQ.sln
05/18/2006  10:05 AM             1,815 DEER DAQ.vbproj.user
05/18/2006  10:06 AM                 0 Error Log.txt
05/27/2005  02:06 AM        10,095,808 EXCEL.EXE
08/04/2004  06:00 AM            32,256 iashlpr.dll
05/16/2006  02:50 PM               280 Init.txt
05/27/2005  02:06 AM         1,089,536 Interop.Excel.dll
08/04/2004  06:00 AM             7,168 Interop.IasHelperLib.dll
05/18/2006  10:21 AM    <DIR>          Lookup Tables
05/17/2005  09:40 AM            64,088 Microsoft.Vbe.Interop.dll
03/18/2003  08:14 PM           499,712 msvcp71.dll
02/21/2003  04:42 AM           348,160 msvcr71.dll
10/14/2005  05:43 PM            62,400 NationalInstruments.Analysis.Standard.dll
10/10/2005  02:58 PM         1,449,472 NationalInstruments.DAQmx.dll
07/12/2004  08:42 PM           102,920 NationalInstruments.NI4882.dll
10/14/2005  05:20 PM         1,168,320 NationalInstruments.UI.dll
10/14/2005  05:14 PM           307,200 NationalInstruments.UI.Styles3D.dll
10/14/2005  05:30 PM           263,104 NationalInstruments.UI.WindowsForms.dll
09/30/2005  10:46 PM           177,088 NationalInstruments.VisaNS.dll
05/18/2006  10:03 AM    <DIR>          obj
05/17/2005  09:40 AM           223,800 Office.dll
05/17/2005  09:40 AM            16,384 stdole.dll
              21 File(s)     16,270,860 bytes
               6 Dir(s)  114,142,150,656 bytes free
Message 2 of 8
(5,844 Views)
Nevermind.  I needed to install the NI-DAQ drivers first, which were uninstalled when I pulled Measurement Studio from that PC.
Message 3 of 8
(5,843 Views)
OK...  As soon as I uninstall Measurement Studio I can't run my installed application anymore.  It may have something to do with the licensing files.  How can I fix this problem?
Message 4 of 8
(5,837 Views)
Is it still giving you the same error message?  Because the first error message implies that you are missing the DAQmx assemblies.  Also are you using .NET to create your installer or are you using another third party program?  If you are using .NET, it will take care of most of the licensing details for you.  This Knowledgebase shows the preferred method of distribution for .NET applications.
Pat P.
Software Engineer
Message 5 of 8
(5,829 Views)
I am using VS.NET 2003 and Measurement Studio 8.0 to build this application.  It will work on a PC that has Measurement Studio and NI-DAQ installed, but will not work on a PC that only has NI-DAQ installed.  The error message is different now.  I can run the application and it won't show up although I can see it using memory under the Task Manager.  After about a minute it pops up with a message saying it can't run.
On the PC with Measurement Studio it was giving me license file errors until I pasted the license files where the MS.NET install is supposed to place them - a glitch that is becoming fairly annoying.  I have four copies of MS 8.0 and they all seem to forget to include the license files about half the time I install them so I have the files stored on a network drive so I can paste them as necessary.
To be thourough....
I unintalled MS 8.0 (which also took out NI-DAQ) and installed my program.  It wouldn't work.  I installed NI-DAQ and it still wouldn't work, but I needed it so I reinstalled NI-DAQ.  Then I thought to try it and it worked.  Then I uninstalled MS 8.0 and it wouldn't work anymore so I had to reinstall MS 8.0 again.
Message 6 of 8
(5,827 Views)
Are you following the instructions that are listed in that Knowledgebase for creating an installer for your application to distribute it to another PC?  Also could you post the specific error message that is popping up?
Pat P.
Software Engineer
Message 7 of 8
(5,823 Views)
I did install it according to those instructions and it works now.
Thanks!
Message 8 of 8
(5,817 Views)
