DAQPad 6070E firewire example
Hi, I am after an example of aquiring data from a 6070E Firewire DAQPad using VB.NET. I know the drivers only work in legacy mode, but if someone could help me to record just 2 channels for 2 seconds @ 2kHz, I am pretty sure I could take it from there.
Stuman
(3,285 Views)
Stuman,
Check out this forum post. It should get you started, I would also recommend checking out the C reference manual. You can find it on your machine at the following location:
Start >> Programs >> National Instruments >> NI-DAQ >> Traditional NI-DAQ Function Reference Help
Also installed are some VB 6 examples, now you will have to access the Traditional Driver calls through function calls to the .dll as that post mentions, but at least those examples will show you how things need to be programmed. Here is where they are located:
C:\Program Files\National Instruments\NI-DAQ\Examples\Visual Basic 6.0
I hope that helps you out.
-GDE
(3,276 Views)
