02-24-2015 04:34 PM
I have a waveform graph where the user can adjust the scale on both the X and Y axes. The "problem" that I am having is that if the scale's range is set too far from where the cursor is at, the cursor will be off screen and not selectable. So, I am trying to center the cursor to the scale when the scale is changed or via a button. Here is the code that I have written for one of the Cursor plots:
Select Case setBlueCursor
Case 1
blueCursorPt.Plot = plotInlineTorque
inlineTorqueMax = yAxisInlineTorque.Range.Maximum
inlineTorqueMin = yAxisInlineTorque.Range.Minimum
blueCursorStartY = (inlineTorqueMax + inlineTorqueMin) / 2
blueCursorStartX = (XAxis.Range.Maximum + XAxis.Range.Minimum) / 2
blueCursorPt.YPosition = blueCursorStartY
blueCursorPt.XPosition = blueCursorStartX
This code will center the cursor like I want but then I can't move the cursor after that as it is "stuck" at the position that I have coded it. The problem appears to be with the last two lines of code here. I do not know of any other way to do this though. I have tried the "moveCursor" method but the end result ends the same way, with the cursor stuck in the center and can't move. Any help on a solution? Is there a better, easier way to do this? I'm new to Measurement Studio and .NET.
Thank you
02-25-2015 12:07 PM
This code works. It appears that I was calling the subroutine that this code is located in over and over in another part of my program.
