merge tdms file
is there an easy way to merge a set of tdms-files (with same structure) to one file?
For example:
Measurement1.tdms
Measurement2.tdms
Measurement3.tdms
to
Measurement.tdms
(5,228 Views)
Hi Andre,
in what way do you want to "merge" the files?
I think you could read the files out in Measurement Studio with the TDM Streaming Lib or the Diadem Connectivity Lib and save the data into one file.
Let me know, if you have any questions.
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(5,209 Views)
This may also be helpful:
NI-TDMS-Dateiformat - National Instruments
https://www.ni.com/de/support/documentation/supplemental/06/the-ni-tdms-file-format.html
Melanie Eisfeld
(5,208 Views)
Hi Andre09, You can have a try to read all the bytes from the TDMS files one by one and then paste the content into one TDMS file. It technically should work if there's no group/channel name overlap, but it cannot be permitted everything can work.
(5,139 Views)
