Change the max range on the x axis measurement studio
I am trying to change the x axis maximum range based on the user input from a textbox.  I am not sure how to do this.  If anyone has any insight, please let me know.  I am programming in C#.
Thanks!
(4,438 Views)
Hello -
To do this, you'll need to create an assign a new Range object - something similar to the following:
waveformGraph1.XAxes[0].Range = new Range((double)numericUpDown1.Value,
    (double)numericUpDown2.Value);
NickB
(4,436 Views)
Thanks for getting back to me.  I used your code that you provided and it did not work.  Do I need to add something.  This is my code:
waveformGraphTap.XAxes[0].Range = new Range(0, 1000);
And I get the following error messages:
'System.Data.Range' is inaccessible due to its protection level
The type 'System.Data.Range' has no constructors defined
Thanks again for the help!
(4,434 Views)
Hello -
It looks like you need to either add "using NationalInstruments.UI;" to the top of your source file, or you need to fully qualify your "new Range(0, 1000);" statement, so that it looks like "new NationalInstrument.UI.Range(0, 1000);"
NickB
(4,432 Views)
Accepted by tylow
Thank you that worked!! Thanks for the help!Smiley Happy
(4,427 Views)
