04-07-2008 05:04 AM
04-08-2008
12:23 PM
- last edited on
03-16-2025
06:04 PM
by
Content Cleaner
Hello Alok,
The DC coupling specification just means that you can have a DC offset in the signal. This does not mean that it applies one without expanding the voltage range. In order to do what you are talking about, your range would have to contain the full amplitude of the signal. You would then add your offset to your generation values directly. You could also do this with external circuitry.
It appears that the reason you are looking for this is because you want to output a very accurate signal. When it comes to absolute accuracy, our DSA devices are not as good as many of our Multifunction DAQ devices, even though it has a higher resolution DAC. This is because DSA (in general) is more focused on linearity, alias rejection, and dynamic range than accuracy. Please take a look at the following KnowledgeBase on this:
Absolute Accuracy of Dynamic Signal Acquisition Devices
If you want to provide this offset like you talk about in your post, you could use one of our 628x devices. This would allow you to provide an offset voltage on a APFI line that is added to your signal.
04-08-2008 12:46 PM
04-08-2008 01:18 PM
04-08-2008 01:20 PM
04-08-2008 01:25 PM - edited 04-08-2008 01:29 PM
Hi
I was about to call Preston. My contact Info is as follows:
email: alok_damle@yahoo.com
Phone +91 98220 56543
Alok Damle
PS: I will delete this post after we get in touch. This is just to make sure internet crawlers dont sniff this address and add me in their list of recipients of Spams!
