 DieselPower
			DieselPower
			03-01-2007 03:30 PM
03-01-2007 04:43 PM
 Yardov
			Yardov
		03-02-2007
		12:46 PM
 - last edited on
		03-11-2025
		01:21 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Michael,
Thanks for using NI forums. As you can see here, the NI 9472 is an output module, so you can only perform output operations. The counters are actually on the cDAQ chassis and are accessible with any input module in slots 5 or 6. You can use NI 9401 for input and output.
For your second post, yes you can, and you will need to be careful in not to use the digital lines that the counter is using. You can see this on the attached picture taken from DAQmx help file.
03-02-2007 12:57 PM
03-05-2007 06:21 PM
03-06-2007 08:13 AM
 Yardov
			Yardov
			03-06-2007 06:15 PM
03-07-2007 08:16 AM
 Yardov
			Yardov
			03-08-2007 06:45 PM
03-09-2007 11:02 AM
