Counter between DO and DI on two different channels
sorry if this question has already been asked, but I cannot find any answer in the forum.
I have to program a solution with .Net that have to count the time taken by a measurement on a device.
My equipement is : NI cDAQ-9188 with NI 9401 device (and also 9421, 9472, 9205 devices)
What I have to do is :
- Send start signal to tell the device he must start de measurment (5V TTL signal)
- Wait for the measurement to finish
- Catch the TTL signal coming from the device (5v TTL signal) telling me the measurement is terminated
- Read the counter to know how many time the measurement took
Here is a schema describing the operations :
NI counter task
Thank in advance for your help !
(3,889 Views)
Accepted by Gasser
Hello Gasser,
If you install the NI-DAQmx drivers they should come with some examples for .net 4.0.  Go here to download the latest DAQmx drivers if you haven't already.  Once installed, go to Start>>Programs>>National Instruments>>NI-DAQ>>Test Based Support to find documentation and examples in .net and C for our daq cards.
David A.
(3,876 Views)
Hello David,
thank you for your answer.
I solved the problem with the code below :
1. Task creation :
// Pulse task
m_nitkPulse = new Task("CO");
double l_dUpDownTime = 0.5 / NbPulsesPerSecond;
m_nitkPulse.COChannels.CreatePulseChannelTime(PulseChannel, "COsPulse",
  COPulseTimeUnits.Seconds, COPulseIdleState.Low, 0.0, l_dUpDownTime, l_dUpDownTime);
m_nitkPulse.Timing.ConfigureImplicit(SampleQuantityMode.FiniteSamples, NbMeasurements);
m_nitkPulse.SynchronizeCallbacks = true;
m_nitkPulse.Control(TaskAction.Verify);
// Timer task
m_nitkCounter = new Task("CI");
CIChannel l_nicicChannel = m_nitkCounter.CIChannels.CreateTwoEdgeSeparationChannel(
  CounterChannel, "DIsCounter", 1E-6, 1.0, CITwoEdgeSeparationFirstEdge.Rising,
  CITwoEdgeSeparationSecondEdge.Rising, CITwoEdgeSeparationUnits.Seconds);
m_nitkCounter.Timing.ConfigureImplicit(SampleQuantityMode.FiniteSamples, NbMeasurements);
m_nitkCounter.Stream.ReadAllAvailableSamples = true;
m_nitkCounter.Stream.Timeout = 1500;
m_nitkCounter.Control(TaskAction.Verify);
2. Pulse generation and time reading :
// Pulses generation and timing
m_nitkPulse.Control(TaskAction.Reserve);
m_nitkCounter.Start();
m_nitkPulse.Start();
m_nitkPulse.WaitUntilDone(-1);
m_nitkPulse.Stop();
// Timing reading
double[] l_ardTimeValues = m_nicrsCounter.ReadMultiSampleDouble(-1);
m_nitkCounter.Stop();
for(int l_nIndex = 0; l_nIndex < l_ardTimeValues.Length; l_nIndex ++)
  System.Diagnostics.Trace.WriteLine(string.Format("{0} : {1}",
    l_nIndex, (int) (l_ardTimeValues[l_nIndex] * 1E6)));
// Unreserve the pulse task
m_nitkPulse.Control(TaskAction.Unreserve);
(3,861 Views)
