CreateVoltageRmsChannel
myTask.AIChannels.CreateVoltageRmsChannel(physicalChannelComboBox.Items[i].ToString(), "",
(AITerminalConfiguration)(-1), Convert.ToDouble(minimumValueNumeric.Value),
Convert.ToDouble(maximumValueNumeric.Value), AIVoltageAcrmsUnits.Volts);
Get the  following error
Who can tell me how to fix it,Thanks
(4,344 Views)
Hi zhangchang,
I think you should try using myTask.AIChannels.CreateVoltageChannel instead of myTask.AIChannels.CreateVoltageRmsChannel. The error seems to indicate your device does not support that measurement type.
Daniel Dorroh
(4,337 Views)
Thanks for your reply.
Another question If I use CreateVoltaChannel,How to set the coupling mode?I wont the coupling is AC. thanks!
(4,330 Views)
