DAQmxCfgDigEdgeAdvTrig
My ultimate goal is to create a stepping function (for example: 0v, 1v, 2v, 3v, 0v, 1v, 2v, 3v, 0v, 1v,...) where the transisition from one voltage to the next is triggered by a digital input signal.
The only way I see to do this is to use the  DAQmxCfgDigEdgeAdvTrig function, but I'm unclear on how to setup the task before using it.
  Purpose
    Configures a switch task to advance to the next entry in a scan list on a rising or falling edge of a digital signal.
I understand it advances to the next entry, but how do I populate the task with all entries, and is it possible to create a loop of events so that I can create the stepping function I desire?
(4,105 Views)
Hi elleryjh-
     The DaqmxCfgDigEdgeAdvTrig function is only used for controlling a switch to move through a scan list of configuration settings.  It is not the correct way to move through a set of voltages.
     You might look at this forum post to get some more ideas on staircase/step functions.
     You will probably end up setting up some logic to increase the voltage of an analog output task based on a digital input.
Best of luck with your application!
Gary P.
Applications Engineer
(4,074 Views)
Accepted by elleryjh
Hi elleryjh-
     I just wrote a piece of sample code in LabVIEW that does exactly what you need it to do.  It might help to see it in LabVIEW then implement it in a text-based environment.
     It can be found here.
Gary P.
(4,053 Views)
Wow that looks great - thank you so much for your help, Gary!!
(4,048 Views)
