07-20-2015 08:38 AM
I have a single line (e.g. Dev1/port0/line7) that I want to continuously read and also detect digital change events and the very same line. As far as I understand the DAQmx .NET library this isn't possible because configuring the timing for the change detected and also as a sample clock won't work, or am I wrong (at least I get an erro)? Here is the code so far
var emergencyStopButtonTask = new NationalInstruments.DAQmx.Task("Emergency stop button task");
var emergencyStopButtonDIChannel = emergencyStopButtonTask.DIChannels.CreateChannel(
deviceName + "/port0/line7",
ChannelLineGrouping.OneChannelForAllLines);
emergencyStopButtonDIChannel.DigitalFilterEnable = true;
emergencyStopButtonDIChannel.DigitalFilterMinimumPulseWidth = 10.24e-6;
emergencyStopButtonTask.Timing.ConfigureChangeDetection(
deviceName + "/port0/line7", // The line where to detect rising edges
SampleQuantityMode.ContinuousSamples
emergencyStopButtonTask.DigitalChangeDetection += new DigitalChangeDetectionEventHandler(emergencyStopButtonTask_DigitalChangeDetection);
emergencyStopButtonTask.Timing.ConfigureSampleClock(
1000.0,
SampleClockActiveEdge.Rising,
emergencyReader = new DigitalSingleChannelReader(emergencyStopButtonTask.Stream);
emergencyReaderAsyncCallback = new AsyncCallback(EmergencyStopButtonReaderAsyncCallback);
emergencyStopButtonTask.SynchronizeCallbacks = true;
emergencyStopButtonTask.Control(TaskAction.Verify);
emergencyStopButtonTask.Start();
emergencyReader.BeginReadSingleSampleSingleLine(emergencyReaderAsyncCallback,
emergencyStopButtonTask);
Of course, because I poll the value of the line every 1 ms dropping the change detection event could be a solution. But I simply want to know if my code is wrong or the DAQmx .NET library does not support the functionality I want. Any other solution then simply dropping the digital change event?
07-23-2015 02:42 AM
Only one task can access one line at a time. You would have to reconfigure the task every time. I would recommend doing software change detection.
07-23-2015 10:05 AM
Thank you for your reply. How do I implement software change detection?
07-24-2015 09:05 AM
Implement it wherever you process the acquired date.
