Evaluation with .NET 4.0?
I recently downloaded the evaluation version of Measurement Studio 2015, however, I did not find that it came with a .NET 4.0 version of the Analysis.DLL.
Is this a limitation of the evaluation version? Does the full version of the Professional version come with a .NET 4.0 version?
Thank you,
John Lindsay
(3,930 Views)
Accepted by JohnLindsay
The Measurement Studio installation is designed to be used with the latest .NET framework for each version of Visual Studio. What this means is that 4.0 support is installed with Visual Studio 2010, 4.5 support is installed with Visual Studio 2012.
If you are using Visual Studio 2010, then installing Measurement Studio 2015 Evaluations for Visual Studio 2010 will automatically install the 4.0 framework.
However, if you are using a later version of Visual Studio, and still need to use the 4.0 Framework, then that can be done by installing Measurement Studio for your version of Visual Studio as well as Visual Studio 2010.
To answer your other question: yes, professional also comes with 4.0. It is a similar process.
Best,
Shamik C
Applications Engineer
http://www.ni.com/support
(3,901 Views)
Thank you very much for the information - I realized after reading your message that I had not installed any support for the previous versions of Visual Studio, as I am using 2013 - it hadn't occurred to me that the previous VS support would also have differing .NET version support.
I have installed support for the previous versions and I am now able to get the .NET 4.0 working.
Thank you,
John Lindsay
(3,897 Views)
