Examples of calling C# form/dll from Test Stand 3.5.
This is possible although; you will need to clarify what result you are looking for. I have code that reads all test data from every step and records that to a .NET dataset which I later write to a database. I'm guessing that is not your interest. So let us know if your looking for a result from a previous step/sequence, measurement, or something else.
Steve
Message 11 of 12
(859 Views)
HI Steve,
Thanks for the reply. I need to check the status ( started, in progress, completed, failed) of the Teststand Process using C#. Please let me know if there is any way to do that and also please share your code, I will try to read the information using that.
Steve
Ravi
Message 12 of 12
(854 Views)
