Here's the output from JIT.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: File or assembly name NationalInstruments.UI.Styles3D, or one of its dependencies, was not found.
File name: "NationalInstruments.UI.Styles3D"
at NationalInstruments.UI.b.GetInnerRectangle(Rectangle outerRectangle)
at NationalInstruments.Restricted.ControlElement.get_InnerBounds()
at NationalInstruments.Restricted.ControlBaseManager.Layout(X layoutArgs)
at NationalInstruments.Restricted.XYGraphManager.Layout(X layoutArgs)
at NationalInstruments.Restricted.ControlBaseManager.a()
at NationalInstruments.Restricted.ControlBaseManager.b(Object , EventArgs )
at NationalInstruments.Restricted.ControlBroker.CallEventHandler(Object eventKey, EventArgs e)
at h.OnHandleCreated(EventArgs e)
at h.b(Object , EventArgs )
at System.Windows.Forms.Control.OnHandleCreated(EventArgs e)
at System.Windows.Forms.Control.WmCreate(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
=== Pre-bind state information ===
LOG: DisplayName = NationalInstruments.UI.Styles3D, Version=7.1.0.306, Culture=neutral, PublicKeyToken=4544464cdeaab541
(Fully-specified)
LOG: Appbase = C:\Program Files\CLS 2005\EXE\
LOG: Initial PrivatePath = NULL
Calling assembly : NationalInstruments.UI, Version=7.1.0.306, Culture=neutral, PublicKeyToken=4544464cdeaab541.
LOG: Publisher policy file is not found.
LOG: Host configuration file not found.
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\config\machine.config.
LOG: Post-policy reference: NationalInstruments.UI.Styles3D, Version=7.1.0.306, Culture=neutral, PublicKeyToken=4544464cdeaab541
LOG: Attempting download of new URL file:///C:/Program Files/CLS 2005/EXE/NationalInstruments.UI.Styles3D.DLL.
