FindResources not returning device
Me: Newbie to NI DAQ. 40 years development, hw and tech experience.
Board: USB-6501 (24ch DIO).
Tools: Visual Studio 2010, .Net 4.0., VB.Net
Task: Build Industrial IO application to read/set digital IO.
Observed: The newly installed USB-6501 device is listed in MAX, but not listed when using "FindResources" from the VB code as shown below.
Questions:
a) What is as a minimum needed NI software/drivers needed to read/set simple IO via USB-6501 from an VB.Net + Visual Studio application?
b) Is the below shown approach sensible / how should I get started?
c) If sensible, why is the device not listed as a resource?
Thanks!
Kay Seljeseth
(4,844 Views)
Accepted by KaySel
NI-DAQmx
(4,839 Views)
Every information I have found for Visual Studio and VB seems to be related to Measurement Studio. Is there any information related to creating a simple VB application directly to NI-DAQmx and the USB-6501 unit somewhere? I do not need tons of user controls and statistics. 🙂
Is Measurement Studio (MS) required for VB.Net programming?
Do I have to buy MS separately (I cant find it in VS after installing the NI-DAQmx sw)?
How about deployment to non-development computers that will run the production software?
(4,827 Views)
Issue solved. The DAQmx development support was not installed for the VS environment. There are quite a few settings in the install package to check/set. I am now able to read the pins using DAQmx directly and so far - so good.
(4,817 Views)
