GPIB 488.2 Board ID's Will Not Reset C#
Make sure that you have NI System Configuration 16.0.1 installed with .NET support. The latest version of VisualStudio officially supported is VS2012. There is an example called ResetAllDevices found at C:\Users\Public\Documents\National Instruments\MStudioVS2012\DotNET\Examples\SystemConfiguration that should do what you are looking for.
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
Message 11 of 13
(1,007 Views)
I have installed the correct version with .Net support. ResetAllDevices resets the devices  the board ID's saved in Windows Registry does it?  Devices and Boards are totally separate classes.
Message 12 of 13
(1,004 Views)
I found this KnowledgeBase article on GPIB register level programming that may help.
GPIB Register-Level Programming
http://digital.ni.com/public.nsf/allkb/DDF4FAB478F48492862571EA00093B20?OpenDocument
Maggie M.
Message 13 of 13
(991 Views)
