Get cfp-180x and AI110 serial number via .NET
I  would like to retrieve the serial number of my cfp-180X with measurement studio.
Should be perfect if I can retrieve, also, the serial number of the AI-110 installed on the cfp.
Do you how to do?
Message 1 of 11
(5,428 Views)
Do you how to do?
What makes you think that Measurement Studio works with Compact FIeldPoint hardware?   All I see is LabVIEW.
Message 2 of 11
(5,421 Views)
Hi nyc,
I can retrieve the serial number from NI MAX.
Pleae see the attached screenshot.
Message 3 of 11
(5,410 Views)
Hi nyc,
And that proves what?
Message 4 of 11
(5,406 Views)
Is a my assumption,
if NI-MAX (not a labview) can access this information probably there is a way to read the serial number.
Message 5 of 11
(5,395 Views)
Is a my assumption,
IF there is a way to access CFP via .NET, National Instruments isn't sharing the information.
All they are selling with it is LabVIEW.
You'll have to assume on your own.
Message 6 of 11
(5,393 Views)
Wha do you mean?
We are using measurement studio to access the network variable to read value from CFP since 2010
http://www.ni.com/mstudio/
I'm not understanding your point.
Bye!
Message 7 of 11
(5,386 Views)
Wha do you mean?
Bye!
I haven't been able to find any documentation. That is what I mean.
If you have found it, go for it.
Message 8 of 11
(5,383 Views)
Hi karpediemnowUSA,
Most of the fucntionality of NI MAX can be done programmatically using the NI System Configuration API. For example, in LabVIEW, a property node from the System Configuration API can be used to find the serial number of NI hardware. If it is possible to programmatically find your cFP serial number it would be through this API. The API is compatible with Measurement Studio 2003, 2005, and 2008. I recommend looking at the link below.
Welcome to the System Configuration API:https://decibel.ni.com/content/docs/DOC-13216
Best Regards,
Andy
Message 9 of 11
(5,347 Views)
Thanks Andy,
Do you know how to use NI System Configuration API in .net framework?
I cannot find any example.
Message 10 of 11
(5,309 Views)
