WaitOnEvent Timing out
Hi All
Trying to set SRQ for power meter (HP437B) via USB GPIB  VISA and waiting for event to return.
When the same thing is done in VB6 it works.
Under given is the code snippet in C# 2010
_gpibSession = null;
_gpibSession = (MessageBasedSession)ResourceManager.GetLocalManager().Open(_resourceName, AccessModes.NoLock, timeOutValue);
_gpibSession.SynchronizeCallbacks = true;
_gpibSession.Timeout = 60000;
_gpibSession.DefaultBufferSize = 65536000;
_gpibSession.TerminationCharacter = 10;
_gpibSession.TerminationCharacterEnabled = true;
_gpibSession.Write("*SRE 64");
_gpibSession.EnableEvent(_mbSrq, EventMechanism.Queue);
_gpibSession.Write("PR");		//preset
_gpibSession.WaitOnEvent(_mbSrq, 6000);          //timing out at this point
StatusByteFlags sbfStatus = _gpibSession.ReadStatusByte(); if ((sbfStatus & StatusByteFlags.RequestingService) != 0) { MessageBox("Request Service in the status register is set."); } else if ((sbfStatus & StatusByteFlags.MessageAvailable) != 0) { MessageBox("MAV in the status register is set."); } else if ((sbfStatus & StatusByteFlags.EventStatusRegister) != 0) { MessageBox("ESB in the status register is set."); string esrValue = _gpibSession.Query("*ESR?"); //get content of event status register }
Any help in resolving this issue is appreciated.
Thank you
Message 1 of 15
(6,725 Views)
According to the documentation, WaitOnEvent method will throw an exception after the timeout you in put in.
Are you getting an exception that is thrown?
Message 2 of 15
(6,720 Views)
Yes I'm getting an exception that is thrown as given under
"Timeout expired before operation completed.  VISA error code -1073807339 (0xBFFF0015), ErrorTimeout"
Message 3 of 15
(6,709 Views)
Where did you get this code snippet?
NI has very good examples on Servest Request written in .NET 4.0 and .NET 4.5
You basically register the handler for the event.
Look in C:\Users\Public\Public Documents\National Instruments\NI-VISA\Examples
Message 4 of 15
(6,705 Views)
One thing you should note is that TerminationCharacter is for read *only*.
You will need to add your own when writing to the instrument.
Message 5 of 15
(6,697 Views)
Ok I checked for NI-VISA examples and only found C & VB6 code.
Message 6 of 15
(6,676 Views)
Then you need to re-install NI-VISA.
I highly suggest appending NewLine to your VISA write.
Message 7 of 15
(6,671 Views)
Already did the re-install and have the new line when ever a write is done.
Can you send me online link to the NI-VISA .NET examples.
Message 8 of 15
(6,666 Views)
There aren't online examples that I know of.
When installing you may want to do a custom install. It is suppose to detect that you have VB.NET installed, but you never know...
Let me repeat yet again. You may be timing out because your VISA write is not complete and your instrument is waiting for your termination character.
Message 9 of 15
(6,663 Views)
I am indeed sending the termination character. You check the code I posted above.
Message 10 of 15
(6,659 Views)
